Essential Tools for Cleaning your MacBook Pro or MacBook Air 2024
Whether you want to believe it or not, your MacBook Pro keyboard will likely get dirty. From the oils on your hands to the dust in the air, you'll need to spend some time every few weeks cleaning your MacBook. If you don't, you risk gunk and grime getting into sensitive parts of the hardware, which could cost you money to repair. The best MacBook is a clean MacBook. It doesn't matter how great our review of the MacBook Air with M2 chip makes the computer out to be if you let it get dirty and stop functioning correctly. If you want to avoid repairs and keep your MacBook, MacBook Air, or MacBook Pro looking clean and tidy, here are some essential tools for cleaning your MacBook.
Note: Before using any cleaning product on your MacBook, MacBook Air, or MacBook Pro, make sure you have powered down the laptop.
A few cleaning tips
Cleaning supplies aren't the first thing you probably think about when considering MacBook accessories. And yet, having them available is very important. Cleaning your MacBook regularly helps prevent any annoying issues down the line and ensures you aren't spreading germs and bacteria as much as possible.
Apple recommends that the only cloth you use to clean your Mac laptops is lint-free, soft Microfiber cloth. They are the must-have cleaning tool in your arsenal. Make sure when you use them, you only get the fabric lightly damp and do your best to keep moisture away from any ports.
Of course, keeping your keyboard clean is of the utmost importance. The butterfly keyboards on Mac laptops have been known to have issues with crumbs getting underneath the switches. Compressed air is some of the best stuff to use to blow out unwanted dirt and dust from your keyboard keys. Apple has a handy guide to using compressed air on your Mac laptop. The key is to ensure you don't use the compressed air too close to the device.
Luke Filipowicz
Staff Writer
