If you find your phone often tapped out of battery power, no doubt you've probably looked into portable power banks. If you like the idea of having extra power with you, but dislike having to carry around the extra weight, you may love these super small and thin power packs!
TravelCard Charger
See at TravelCard
Truly designed with portability in mind, the TravelCard Charger is a mere 4.7mm thick, making it actually small enough to fit inside your wallet with ease.
While its capacity is only 1,500mAh, it does have a few key features that are included in every power bank this size. The LED indicator will let you know when it's time to fill it up again, and it even has the ability to be charged while charging your device, so you should have no problem killing two birds with one stone.
The TravelCard will cost your $29 and has a built-in cable for Micro-USB and Lightning ports, so you shouldn't spend time having to untangle cords while you're on the go.
Lankoo power bank
See at Amazon
The Lankoo power bank is for the serious power consumer. It has a capacity of 5,000mAh, meaning any iPhone you've got should be able to get a full charge from the Lankoo.
On top of its impressive capacity, the Lankoo also offers fast charging speeds. The one USB port is certified 5V 2.1A charging speeds, meaning it shouldn't take you too long to recharge any phone.
The added bonus of the Lankoo, it comes in all sorts of fancy designs and colors making it visibly stand out from the rest of the competition and it's only about $30!
Tylt Slim Boost
See at Amazon
Next to the TravelCard, the Tylt Slim Boost is the smallest of the bunch, and as its name suggests, it's incredibly slim so you can fit it in your wallet.
It has a 1,300mAh capacity, so although it would completely charge up your iPhone, it should be enough power to keep you going until you get to the next power outlet.
It comes with an integrated Lightning cable, so you don't have to worry about carrying your cable around with you. You can pick the Tylt Slim Boost in white, black, or gold, starting around $15.
What do you use?
Do you have a tiny power bank that packs a wallop? Let us know in the comments below!
Updated May 2018: If you're looking for small size battery chargers, these are still the best options on the market.
